HEI ignition
karl
in Street Rods
Where can I buy an HEI ignition for my 308 Hornet engine?
Pertronix, summit racing sells the units. You can call pertronix and get the part number you need.
If you're handy with circuits:
I made one like Fig.3. Worked really well.0 -
How about 6 volt + ground?0
Ah nuts, not with an HEI. They are only happy at 12V as far as I know... Since I converted to 12V I forget about 6V positive ground... Pertronix would be your best bet then. Though I'm curious now, and will pick the brain of one of my electrical controls co-workers tomorrow...0
I thought I saw a complete HEI GM distributor modified to fit 308 engine. Am I dreaming? If so, might anyone out there be familiar with who makes this ,modification.0
Not sure about the 6-cylinder HEI but a distributor from a Chrysler slant six just about drops in. You replace the inner shaft of the Chrysler unit with the Hudson inner shaft and trim a fee thou off the distributor body to fit the 308 distributor bore. You can then trigger a HEI module with the trigger in the Chrysler unit or run a straight Chrysler electronic ignition.
I’m running HEI Distributor in my 46 straight 8 Hudson Pickup. It came from Charlie Harris, running 12 volts.0
Karl - Ron Fellows (HET member) of Pennsylvania has made Chevy based HEI distributors for Hudson’s0
I have the pertronix in my 39 for the 212 CID it works fine0
With today's technology and miniaturization there is really little need to resort to trying to modify the old HEI distributors. The Pertronix is simple, easy and relatively cheap to buy and install. Yes for the tinkerers the HEI and Mopar mods might be fun, but in the end just go with the most modern solution. The fact that Pertronix actually makes these for Hudsons (6V pos ground, plus 12V neg ground for those that have made the conversion) is somewhat amazing!0
I have a pertronix conversion in my 51 Commodore 8 6volt positive ground that works great.
The distributor is difficult to get at in the car because it’s very low at the rear. I removed the inner fender and used the recommended coil from Pertronix. You also have to replace the coil and plug wires with suppression type wires. Solid copper wires can not be used.0 -
The Chevy 6 HEI Distributor fits Hudson Block but needs an adapter to extend the Hudson shaft. Ive installed Crane XR700 Point Eliminator Kits in my distributors but they are 12V.0
29sptphaeton said:I have a pertronix conversion in my 51 Commodore 8 6volt positive ground that works great.
I did the same with my 49 8cyl. Looks stock but has very hot spark.0 -
It is great they have these available now for the 8. Back in 2005 when i was getting my '50 on the road they offered to do a one off for $350, I said no and rebuilt mine. So another amazing help for the Hudson engines. I wonder sometimes how many 8s are still on the road?0
I keep mine on the road $$$$$$$$$$$$ its just money ! LOL0
Thought I should share this, my pertronix is acting up and I think it is done. I spoke with the tech rep from pertronix today. I asked a few questions as to causes. I told him I got my plug wires from YNZ and he informed me that the unit will not work with those wires as they are solid core. It was cause erratic and complete failure of the pertronix ignition and coil. Guess I have to go back to points. Unless I change plug wires0
I suggest changing S/plug wires....0
I still may do that but I am putting points back in for now. Maybe a can find the original look in a wire that will work with the pertronix system0
You can buy Black original looking 7mm suppression wires from speedway.
They have them listed in the flat head Ford section.0 -
Thanks, I'll check that out.0
If it is the moroso brand wire set they don't seem to be cloth wrap. But that may be my only option if I want stay with the electronic set up0
