POWER STEERING CONVERSION
47s did not have a PS options only '54 and later. Best option is to go to electric PS, but you will need to switch to a 12V system to do it.0
Ive installed GM Power Rack & Pinion to my Straight Axle Hudson's then mounted the P/S Pump to the Hornet motor. It was not difficult.. However, '47's are Coil Suspension so need to extend the Steer shaft down to the Rack using a small universal joint with a 3/4" Heim and fabricate a mounting bracket. Rack's come in different widths but be sure to get a Rack from a 'Rear Steer' car.. Might have to shorten or lengthen the tie rod sleeves slightly and maybe make a bushing into steering Arm's...Lastly, Might have to shorten Steering Arms slightly because Rack's don't have the range to turn real sharp.... Can be done but may be a Project..
Additionally, last Yr at the Eastern Regional, there was a beautiful light colored '30's or early '40 Hudson Sdn there that had a Toyota P/S Box that he said practically bolted in, however, I don't recall the year of car or if had a Coil Suspension... Perhaps like Ken U Tex suggested, John Pontius might know more...
This gives me some good starting points to look at, thanks everyone. Not much is remaining original with this car, the old shift linkage and column will not be used as there is now a small block Chevy/ TH350 installed. This is a customer's car sent to my shop because I am known for custom builds not OEM. We are close to completing a 2 year rotisserie restoration of the body and steering is one of the last frame/suspension mods to be made.0
Since the car has been heavily moded already and probably 12V system I again would recommend electric PS as it would be the easiest to install in such a case and no need to mess with the front steering gear etc. There are several threads here on this subject on this forum and many youtube videos on low coast approaches. I am installing such a system in my '58 Studebaker pickup as I can eliminate one extra belt and pulley and have a much cleaner engine compartment without the pump hoses, etc.
https://openforum.hetclub.org/discussion/170047/electric-power-steering/p1
I would install a GM Tilt Column with the GM P/S Box or run a shaft to a Power Rack.then any modern St Rod Wiring Kits would plug right into the GM column Plugs.. ( I installed a few Tilt's in my '37 & 47 Hudson's...Have many choices....0
here are pictures from my 52 Wasp ps project.
https://www.snapfish.com/photo-gift/share?via=link&token=-dhPzEpv5ACoLDmZt_oVzA/SFO/27947419107060/SNAPFISH
column with electric unit installed.
here is unit mounted
unit viewed from inside
First testing, trashed this and built the riser.
That looks great, so the bridge over works well? This should be the way to go if it works as good as it looks. If one wants to go with the GM tilt columns they also come ready to go using Ididit units: http://www.jegs.com/p/Unisteer/Unisteer-Electra-Steer-ididit-Steering-Column-Kits/3029244/10002/-10
Back in the day..... I did use the mustang power steering cyl. I was located underneath. You had to weld an "eye" on the drag link, but worked great on many cars. I had a 28 chevy stock axle that I did it on. Pretty easy, keep all your steering parts, etc. The cyl. are still avaliable. Hope this helps.0
- 118 Hudson 1916 - 1929
