Wanted . Pinion gear. 157531
You will need to specify pre-step down or step down. If pre, we need to know if it's 6 bolt or 8 bolt too.
Allen this is a pinion gear for cars from about 1941-47.0
Ill have an entire spare rearend in the next week or 2 if you need one. Its located in western mass0
Thanks Jimmy,I am in Australia,so hoping someone here has one.0
Les, if yoiu just want the pinion, any pinion from 1934 to 1947 should do the job. Good luck mating up a non-paired set thyough!0
Yes Geoff, aware of the fittment, have a guy who is willing to have a go at matching the pinion with the crown wheel I have.Not many 8 stud sets around. What have I got to lose.,??0
