Center steering arm repair kit for 1952 Hudson Hornet
FinnHudson
Could someone help me to find a center steering arm repair kit for 1952 Hudson Hornet?
Courtesy Man wrote:If the pin is OK, I sell a center point bushing to replace the Torrington needle bearings. With new lock nut the cost is $30 plus $5 shipping. If you have questions you can email me at : HET gtkristi@copper.net or ask here how it worked for them. Gert Kristiansen, Deseret Chapter.
https://openforum.hetclub.org/discussion/155466/acceptable-center-steering-play0 -
Kdancy,
Thank you for good information.
I havn't disassembled the center steering yet. I have to do that first I can see if the pin is worn before I shall contact Gert Kristiansen.
How much is correct diameter for the pin?
Hi, thanks for the interest in the bushing kit for the step-down Hudsons. My e-mail has changed to: HETgtkristi@comcast.net. Inflation has pushed the price up to $35 + shipping ( $6 in USA ). Let me go out in the shop and measure the pin ( I think it is 1.000 on the micrometer - will verify) Gert Kristiansen PS I also make the distributor - oil pump alignment tool.0
Yes the pin is at 1.000 more serious than a few thou undersize is if the pin is rusty where it would chew up the bearing/bushing. If the pin is bad look for a used replacement or buy the new pin from Randy and Russ Maas at 21st Century Hudson - you would then need to have a machinist align the pin and machine a taper-pin attachment to the housing. On my e-mail remove the "HET". Mange tak (I am Danish).Gert Kristiansen. PS the alignment tool is only for the "Big six" Hudson.
Our kit contains a new pin, washer, bushing, nut, #5 replacement tapered pin for $85 plus shipping. Randy Maas maasfh@centurylink.net Ph 309-267-6158
Gert,
tack så mycket.
I'm ready to order when you will tell the postage fees. I sent my shipping address by email.0 -
Randy,
thanks. I have sent an email earlier today to you.
Jaakko Kuru0 -
Tried your regular email listed here - but came back. Last time I tried PM here I made some " terrible " mistake so if you can email me as above I have shipping cost - let me just give you that :Priority mail 6-10 day at $33.95 or 1st class varied delivery $13.50 to Finland - I take PayPal or other. Gert0
Thaks Gert,
I'm not so busy 1st class is OK for me. I shall pay $35+13.50= 48.50 immediately by PayPal.
Thank you very much0 -
Thank you I have received payment. Gert0
- 118 Hudson 1916 - 1929
