Difference between 1932 and 1933 Hudson terraplane
Just bought a Hudson terraplane body. Was told it was one of those 2 years. Is there anyway to tell the difference so I can apply for a title. Thank you michael
If the dashboard is there, you may be able to tell from the instruments.
They were different in 1932 and 1933. Only problem is that I'm getting mixed signals from the internet as to which photo is for which year. The dashboards are identical in '32 and '33 but the instruments are made differently.
Here, the markings on the gauges are stamped out of the metal so that (I guess!) the light comes through from behind. Left gauge says "Terraplane" only.
While in this one, the markings are printed to the face of the metal. Also, the fuel / heat gauge says "Essex Terraplane". One is for 1932, the other for 1933! I'm sure that someone more knowledgeable than I will jump in here, and say which is which!
First picture is from a 1933 T six. Second picture is from 1932 Terraplane. Most of the
other differences are in the frame,chassis and fenders as well as Hood length. Frame has
serial #s stamped in multiple places but I'm not aware of and numbers on the body except the tag on the passenger side firewall (engine side).0 -
I have a gauge that is stamped that says Terraplane 8. I'll try to Take picture tonite.0
I think the grills are different also. One has crank hole and other don't.0
Well, looks like by the gauges I have a 1933 Terraplane T six. Thank you for the help and guessing I will need more help later on during the build.0
33 did not have windshield visor, 32 did.0
32 visor was fixed, you clearly have a 330
- 118 Hudson 1916 - 1929
