For 1923 4cyl. Essex Floating coupling (Oldham Coupling)
Gemo
I believe this coupling was used on all Hudson/Essex 1923-1932 ? I need one, or better still a complete assembly. Any help welcome
Welcome to the Forum, Geno. Is this some sort of universal joint?
My understanding is not all Essex had this. As I understand it there are two types of drives one a gear and one a chain. This is for the chain so any slack can be taken out. My 1922 and the dead 1923 engine I have are both gear drive.....sorry. Someone with more experience with this will chime in shortly I am sure.
Jay
Yes I have spare. Has your's broken? What other parts may you need. Shipping from NZ is costly but the parts are small. Email me at HETtriangle@het.org.nz (drop the first HET)0
This system was used on all Essex 6's through to 29 at least. Not sure on 30's and up though.0
Hudsons used a similar coupling. Not sure if its the same. Would like to know. If its the same then it would be very easy to find. Barry0
barrysweet52 said:Hudsons used a similar coupling. Not sure if its the same. Would like to know. If its the same then it would be very easy to find. Barry
Jon B said:Welcome to the Forum, Geno. Is this some sort of universal joint?barrysweet52 said:Hudsons used a similar coupling. Not sure if its the same. Would like to know. If its the same then it would be very easy to find. Barry
The coupling was invented by a man called Oldham in about 1850. He used it to drive the paddles of a steamship. Hudson used it to keep the timing chain tension correct without disturbing the oil pump/distributor drive.
It allows a shaft to drive another shaft which is offset to it.
Thought you'd like to know this!
Gemo
- 118 Hudson 1916 - 1929
