35 door check
Hello all, wonder if someone can help.
I'm working on my doors and notice there are no door check rods to stop door swing in mine. I have seen pictures and it appears to be a curved round rod with flattened end with a hole to pin to body post. They ride in a rectangular channel with a rubber on the end so wonder if the end of the rod is rectangular or has another piece attached. I figure I can make them up but not sure what it looks like inside the door.
Does someone have one out they could share a picture of? Or coulpe spares they would part with?
Thanks much, Jake
Thanks much, Jake
Could you mention which year Hudson (or Essex, or Terraplane) this is for, and whether the front or rear door?
Hi Jon
35 Hudson, 2 door sedan.
Thanks0 -
I believe they are the same on 4 door front and back too.
Thanks0
