Dale Cooper
pmlmbigpondcom
G'day All,
Does anyone have a fax number for Dale Pls ?
My email is not getting through
Thanks
phil
Australia
Thanks
phil
Australia
Ken,
Pls see list below
Thanks
All for 1937 larger port engine 8 cylinder
Set of 20 thou pistons and rings PREMIUM pistons and rings
AndComplete engine rebuild gasket set – prefer copper / asbestos head gasket if possible
And
Another “spare” set of sump gaskets
And
3 x clutch gaskets
And
Clutch throw out assembly including bearing and seal x 2, ie two complete units pls.
Phil0 -
Phil. We have every thing in stock--pistons, rings, pin bushings, gasket set (No copper), front timing sleeve, lifters, guides, valves, valve lifters. Can ship Monday--Call 309-267-6158 or email at maasfh@centurylink.net, Fax 309-968-7077. Would be glad to help
Randy Maas--21st centuryhudson
21stcenturyhudson.com
Phil--also have clutch gaskets and throw out bearings.
Randy Maas
Randy
I have sent you an order
thx
Phil0 -
Phil, are you checking your pm's ? Dale said he had sent you one.0
- 118 Hudson 1916 - 1929
