Wanted: H8 Engine
50ClubCoupe
Looking for an H8 that will fit a '37 Hudson 8. Would like to find an engine along with transmission but let's start with the engine first. I'm located in NC and can travel a little if needed.
37-47 is a match for the original. If you wish to retain the floor shift,then need 36-40
trans. 39 and 40 trans will need the shift stalk and trans cover from 36-38. 48-52 8's can be made to fit but the 41-52 trans is designed for column shift. Lots of possibilities !0 -
JB posted this earlier this year: http://hetclub.org/index.php?option=com_kunena&view=topic&catid=16&id=2933&Itemid=13670
