vacuum wiper motor
Is there anybody with a original 54 hornet motor that is having a problem keeping the outer cable from moving when the screw and washer are tight. If so how did you fix the problem . When this problem is fixed our car will go for a out of province safety inspection. Thanks for everybodys help . Ray
Ray,How about just wrapping some fine wire around the cable to increase the diameter a bit. That might allow the washer to clamp the cable to the housing.0
Sounds like a good idea. I will tell my friend.
I had one of those things that would not clamp and found that the wire was frozen inside the outer cable. Make sure it moves freely..0
The cable is free and the motor is freshly rebuilt. Thanks for the help .
Halilulia my friend found out why the cable was moving on the wiper pump inside of the switch it was slightly seized lubed it ahd some of the cable. Started the car and the wipers move good. Just waiting for the person from the garage to come and do a out of province safety inspection.We are so happy and excited for that day. I would like to say THANK every body that helped us with info and pictures.We started the car in 2003 along time. Ray
- 118 Hudson 1916 - 1929
