Looking for left rear door tinted glass for 53 Hornet 4dr sedan
I'm installing the windows back in the 53 Hornet 4dr sedan I have been working on.
The drivers side back door glass is factory tinted and has a 6" crack on the bottom.
I'd like to replace it if I can find another one, doesn't matter about some de-lamination, just
needs to be in good shape.
Anyone ?
Upate ---- The local auto glass shop installed the new tinted laminated glass into the window track.
I have it installed and can't tell the difference in color, good match.
Total was 106.00 including tax.
Kerry,let me know if you find more than one,same one cracked on mine.0
Take the dead window to one of the larger glass merchants, they will be able to cut one for you in the correct colour and thickness laminated glass.0
Bob, after reading your post, I called my local glass company and they said they could cut me a new one in Green Tint laminated glass. So, I will take it over monday and see if they actually can!
Thanks!!
Update, just went on over and dropped it off. Will report back when I pick it up.
Updated in first post.
