46 Super Six Coupe
You may have an issue with the steering pitman arm bolt. A grinder will shorten it enough. Otherwise it should be an easy swap.... I think... LOL0
You could use an earlier '37 thru '46 8 cyl motor as well. Same output, just different block and sump.Geoff0
You'll need to find or make a couple of brackets to mount the radiator on the crossmember. Holes are there. The motor goes in the six cyl radiator holes.0
