37 terraplane
Are you looking for the packing material for the cap-to-block joint? There was originally no rear main seal in those engines, so if you mean that, then it doesn't exist.
If the former, I think Dale Cooper can supply it.....I recall it on the list of stuff in "Gaskets".
Also, look for a restricted or blocked drain tube, that little brass tube with the "flapper" valve on the bottom end, or the drain hole in the rear main cap itself.
Frank
Sydd,
There are a couple of other possible sources for leakage from threaded holes through the rear adapter plate into the block. Some are "through holes" into the crankcase. I wouldn't expect those to cause a great deal of leakage volume. I have too much of the packing material here so I can send some if you like. There's always plenty in the gasket sets and it doesn't need to be a continuous piece. I have a few of the cork gaskets for the slinger housings as well which could also be a source or contributor to your leak.
I like to work some silicone sealant into the "rope" as I pack it into the hole with a blunt punch. A little in the upper corner of the block and a very thin coat along the rear edge of the cap-block interface is advisable, too.
Excessive rear main bearing clearance may overload the drain-back passage, dumping the excess past the slinger and out the back.
F
I have some asbestos rope which we have used for 30 or 40 years to pack the rear main bearing, if you need some give me a call, as I said used it for years and has never done me any harm, at least not that I know of.0
- 118 Hudson 1916 - 1929
