steering wheel removal
Try the 50/50 Acetone/Dexron mix0
I just swapped mine out last night but I think I got lucky. I didn't have a puller handy so I used a couple of long bolt secured in a slide hammer fixture. I only had to give it a couple of (delicate) raps with the slide hammer and she popped right off.0
They tend to seize a little over time. I usually put tension on it with the puller, then gently tap both sides of the back of the wheel to get it to "pop" off.0
- 118 Hudson 1916 - 1929
