What size wheel bolts on 1939 112
PaulButler
Administrator
I'm going through sorting out brakes etc. on my 112 and have found a rear wheel where all the bolts are in a poor shape.
Any idea what size/type thread is used on these?
I want to see if I can possibly chase the threads before going down the "new" route so would need to purchase the correct size
Paul - Look here... And, they shouldn't be nuts, they should be bolts -
https://www.facebook.com/rick.clark.16/media_set?set=a.4215835398228.2176586.1355373652&type=3
They are the same 'bolts', spanning multiple years.
Reading on the box shown:
Manufacturer: DORMAN
Part No: 610-018
Description: 1/2-20, WHEEL BOLT
Bar Code Number: 19495 607180 -
1/2 UNF, 20 tpi. It won't be too hard to find good replacement wheel bolts if you need them, a thread gauge is also a useful tool for restoration work.Probably a good idea to buy a tap and clean out the drum threads too.0
