'53 Hornet Ignition Issue - Advice welcome!
What happens if you rig a hot wire from the battery and touch it to the small terminal on the solenoid?0
Park, I haven't tried that yet. Should I hear the switch click open inside the solenoid? Or should I expect something different?0
Would suggest jumping the "S" or the "I" small terminal?0
You've got a later 12v Ford solenoid if it's got the "I" terminal. For the test, you want to jumper to the "s" terminal. The solenoid should click and the starter should run.
The "I" terminal has power on it only when the solenoid is energized. It's for 12v cars that have an external ballast resistor. If connected to the "coil side" of the ballast resistor, it provides a full 12v to the coil when the engine is cranking.
Thanks, Park. I'll go give that a try and report back.0
Park, I jumped the "S" terminal and it did exactly as you said. The starter turned right over.0
That would suggest a problem at the ignition/starter switch, the power feeding it, or the wire from it to the starter solenoid. Looks like you may have to do the "man disappearing under the dash" maneuver. Or you might be able to reach the switch from the top by removing the radio speaker grille and speaker.0
Thanks, Park! I've been under the dash and it's spaghetti. LOL Is it more likely that the switch simply went bad or that a wire came loose/grounded? My gut says wire. sigh.0
You might try jiggling the key while you hold it in the "start" position. If that brings it to life, it would pretty much confirm that it's the ignition switch is the culprit.0
If it's an automatic transmission it has a neutral safety switch. Try moving the shift lever around while holding the key in the crank position. Parking brake On! , foot on brake pedal!
It may need adjustment.
Thanks, Park and lostmind. I've started the post-mortem on the ignition. I've found some sketchy conditions on the wiring from the neutral safety switch to the solenoid. Thought I would start by by-passing the neutral safety switch in the morning. If that worked, then I would just replace that wiring run. After getting really deep into whole wiring "upgrade" done back in the 90's, I'm strongly considering replacing the entire wiring harness. It would cost time right now, but may save time and headache in the long run. Does anyone have suggestions on harness suppliers that won't eat up the rest of meager budget too badly?
Murphy's Law, subclause 91(a): All modifications to improve performance will have an inverse effect on reliability.0
Yas, and anything you do to fix it will only make it worse0
True, Geoff C. I'm just looking for reliability at this point! LOL0
There are several companies that can furnish exact duplicates of the original wiring harness. The problems are that:
1) They ARE pretty pricey
2) They are the original layout. You have a 12-volt conversion and no telling what they have wired to what!
If upon inspection you find that the quality of the wiring itself is fairly good, you might just go with what you have, and just carefully inspect all the connections and terminals to make sure they're good. Also note wherever the wiring passes through a hole in the body, to make sure that the insulation hasn't been worn away.
Of course, if any of the wiring is of the original cloth-covered type, THAT you will probably want to replace with modern style wiring. But if the existing wiring is still pretty good, no need to spend good money for new wiring that won't be that much better.
Shane, where are you located? Most Hudson folks are friendly and helpful and one of them might live in your vicinity, have a similar car, and be able to lend you his (or her!) expertise.
Jon B,I found many abandoned wires, loose wires, unsheathed wires, electrical taped wires, etc. It was very disheartening, actually.
I'm sure I could have solved the immediate issue, but it gave my wife and I concerns about future reliability.I looked at several wiring harness options. You are right that some are very pricey. This is a car for my 16 yo step-son and will be used as a daily driver more than a show car. I bit the bullet and bought the American Autowire Highway 15 kit. So if anyone has experience, tips or suggestions, I welcome them all!I'm in the Middle Tennessee area. Murfreesboro to be more exact.Thanks!0 -
Shane:Try this link to my '53 Hornet wiring trouble, http://openforum.hetclub.org/discussion/167726/53-hornet-wiring-dilema#latestgood luckJ Lombard0
Shane: "Been there!" When I first got my car, the wiring was a mish-mosh of old & new, but with an emphasis on "old" (i.e. cloth insulation, mostly frayed). Being penniless at the time I simply bought rolls of vinyl covered wire and (to the best of my clueless ability) constructed new wiring.
Do consult a wiring diagram if you have a manual. (Downloadable manuals are on the H-E-T site, for members).
Meanwhile, disconnect your battery when not using the car! And carry a fire extinguisher when you are!
Jon:Good advice.J0
Thanks, J Lombard. I read through your conversation. I did go through and checked the safety neutral switch previously. It appears to be working fine. The car was running just fine on a Saturday night when I packed my tools up and then wouldn't do a damned thing Sunday morning. It was while trying to chase down that issue that I discovered the sad shape of the wiring. My wife, who's son will be driving this car, strongly seconded my thoughts on just installing a new wiring harness after she looked through some of wiring, too. LOL0
Jon B.,Thank you! I have the wiring diagrams you reference. I have the '52 Mechanical Procedures Manual, the '52 Group Parts Catalog, the '52-'53 Hydra-matic Transmission Supplement, and even the '53 Sylvania Radio Manual. What I still need to find is the '53-'54 Mechanical Procedures Supplement.
PS. Always have a fire extinguisher close.
shane0 -
The 53 - 54 supplement has the wiring diagram for the 53. I know no help at all. I will say Y & Z makes a great harness and everything is labeled. But it is pricy.
Sorry Jay
Would suggest that POR15 be used before all the wire pulling~~ WHY leave the metal rusty !0
I just used an RI Wire underhood and dash kit on my 1951 Commodore 4 DR. Where the wires didn't show, I used generic fabric-over-modern plastic insulated wire to save a few $$$$. It is a driver, not a show car!
Results were great, although I wish I had followed Ken's tip about laying out the old harness on the garage floor, perhaps side-by-side with the new one. One thing I would add is that it is important to take pictures that show how the harness feeds through the body and which wire passes through what aperture. This can be surprisingly confusing. Also, misaligning the main cable by an inch or two in any direction can mean that some leads will be too short.
I followed the instructions that came with my Sears bungalow in 1927 - "if it doesn't fit, don't cut it. You have it in the wrong place."
The results are wonderful!
Thank you all, Gentlemen. I appreciate all of your advice! The pics were also very informative, Ken. Thanks!0
Shane-I've done one of my Hudsons with Hwy.15 wiring type-of kit and another one with a YNZ Wiring Harness. Yes, YNZ is more pricey, but worth every dime in my opinion. I wired my car with the pre-made harness in less than a weekend. The time and headache you save is priceless, at least to me.0
