Sway bar won't go back on
I bought the rubber bushings for the rear sway bar and put them on. Now I can't get the sway bar to line back up. It's almost as if it shrunk when the new bushings were installed. Am I missing something here or is there a method for re-installing the sway bar that I'm not a aware of.
Jason-Last time I did this, I pretty much used the method Ken described, but I still had to pry the body over just a little in order to get the bolt through. That was with new springs, as well, which added to the "tightness".0
Panhard bar ??????????????????0
- 118 Hudson 1916 - 1929
