1954 trunk hinge needed
Dave if the rivets are sheered they can be replaced or use bolts. Buddy of mine had rivets fail (54 coupe) at a recent regional. We went to local hardware and fixed hinge.0
Thank you Rivet replacement was no problem, but it is bent in several places along with a crack that I was able to weld. If we can get it to work, I would still be leery about tasking it on trip.0
Dave there is someone selling 54 hornet or wasp parts on craigslist auto parts in Portland or. But the address is Iron range minn. You can check it out He has a picture Good Luck John0
Dave, sent you a pm0
When I was doing the hinges for the trunk I glass beaded them and blew all the dust off and silver painted them. WheIl I installed them and went to close the trunk lid the hinges bent badly .So finely I sprayed then with silicone graffite chain saw lube. And now I can open and close my trunk lid with my little finger.Oil helps lots.Hudsonly Ray 54 Hornet Hollywood0
Not going to make it to Doc's meet this weekend Dave. If you don't find a better lead, I can send you pictures and if you want to try it, I'll send it to you.0
Thanks for replies. I am picking up a pair at Central Regional next month.0
