Visor pics for Keith Fullmer
RL Chilton
Administrator, Member
I had a request to revive an old thread where I showed pics of windshield visors. However, the pics are no longer visible, so I am starting a new thread.
These pics are all of a visor with the brand name, "Kar Kraft", I believe it is spelled. Typically aluminum. You'll notice there is a cut-out in the middle at the top to go around the antenna. These are specifically made for step-downs, '48-'53. '54 has a different configuration, as they do not have center windshield divider (also hard to find).
If you decide to try and find one, they typically sell in the $350-$500 range. Upper end being for an unused NOS example. Also, don't forget a "Duo-Glide Traffic Viewer" for the dash. Makes seeing traffic lights much easier, particularly the old 4-sided ones in the middle of the intersection you still see in small towns. Any other pics you need, let me know.
1
Thanks loads for the visor pics. They help a lot! BTW, what a beauty of a car!...k0
do you need any more pics from a different view?0
I think I saw a post that Bent Metal was reproducing the brackets.. Is that true? I have a fiberglass repro visor that looks to be a replica of the Original metal one but no brackets. I might want to install it on my latest "resurrection"0
- 118 Hudson 1916 - 1929
