stepdown head bolts
Randy Maas 309-267-61580
Dale Cooper is also a source of Hudson equivalent new manufacture head bolts.0
Big Paul has these. He sent me a set. Bolts and hardened washers.0
THE 7/16 ONES I SELL HAVE 11/16 HEADS NOT 3/4 BUT WITH THE HEAVY WASHERS THEY WORK GREAT AND THEY ARE ONLY $25 FOR ALL 21 BOLTS WITH THE WASHERS ALSO THE BOLTS I SELL ARE ALL GRADE 8 BOLTSJUST A NOTE IF YOU HAVE OFF YOUR HEAD FOR ANY REASON LIKE CHANGING YOUR HEAD GASKET MOST LIKLY THE BOLTS HAVE NEVER BEEN CHANGED BACK IN THE DAY THEY DID NOT HAVE GRADE 8 BOLTS THEY ARE MUCH BETTER THAN THE ORIGINAL BOLTS AND HAVE NEVER SEEN A GRADE BOLT BREAK OF STRIP0
Dale Cooper sells a high quality set of head bolts, washers, and whatever else you need.
