3rd brake light
John, in the back of the AACA mag there is an advertisement for a 6 volt LED 3rd brake light. . They come with suction cup an adhesive mount. The cost is about 55.00 It has both turn signal and brake light hookups. I have used them on all my 6 volt Hudson's as well as some of my other 6 volt oldies. They works real well,
If you can't find the listing, I'll take a look and send it to you
Lew
Lew
Would you post the information here for the rest of us too.
Thanks, Lee O'Dell
Lew'
Thanks for the info. I do have one of the LED lights, but would prefer one that mounts on the rear window shelf. I bought one at a flea market, drilled the holes in the back panel, wired it up, only to find out it the unit was defective. I now have three holes in the panel that are quite ugly. I may have to just replace the vinyl and use my LED.0 -
I'll bet I don't need to say this, but.....I've found a few 12 V units that work fine on 6 but that's not usually the case and LEDs are polarity sensitive so a positive ground installation may present some challenges. The one I've used is for 12V Neg earth and has left/right/stop/tail capabilities but in order to make it work on Pos earth, I have to connect all wires together (except ground, of course) and connect them to ground, then use the "ground" wire to Negative ("hot") in the 6V pos earth system.
F0 -
Great tip. That beats the crap out of what I did but mine works well. I'll know what to do next time though.
F0 -
Here's mine: 3 'bee-hive' lights
#30109 from taillightking.com
Sorry for the poor pictures.0 -
I got mine from www.jandlenterprise.com
I got mine from them tooit works great and good to deal with.Jeff
Works great and wilth a little imagination you can put them in without cutting any holes
Here is a 90's Chevrolet Suburban brake light that will fit between rear guards and can be installed with epoxy or magnet glued to bottom. They are polarity sensitive.
I made a third brake light using the trunk emblem. I cut out the spaces between the letters and put a red lens and some bulbs behind it that were attached to the brake lights.0
Post a pic Jason. Sounds neat.0
Okay Dave,Here are some pics of the homemade 3rd brake light.0
Jason, That is one great idea. I just might have to check out my 54 and see how it would work for me... Thanks!0
I thought this up about ten years ago. What's really neat is that in the daytime, it looks just like a regular trunk emblem.0
- 118 Hudson 1916 - 1929
