Gasket
I assume you're working on the Dana axle, John. The blow-up figure and parts list in the factory service info don't show a gasket there on either side; only between the backing plate and the "grease seal cap" on both sides.0
Ken,
Yes, I do mean the cap that holds the outer grease seal. This car has turned out to be the hornet from hell. A lot of things on the car are not correct and are causing more problems than I expected. Just one problem after another. Not to be deterred, I keep going and some day will get it road worthy thanks to all my forum friends.
Thanks,
Videoman0 -
John-You bought the "Satan of Morimar" car? LOL! Sorry about your troubles! Hang in there and solve 'em one item at a time. In the end, it will be worth it.0
Don't tell me......it was billed as a "Daily Driver", right?0
"Ran when parked"
