Hudsons on ebay
currently there are 8 hudson's then below that they put a thin line and list "More items related to "hudson"" these ads say hudson somewhere in the description so they think we want to see them too. More advertising games from eBay it looks like to me.0
Richie... the poster of any auction ad can place " key words in their advertisements" In the past I had a lot of ads that popped up because the seller was located in HUDSON ... anywhere USA. If you look at the computer code behind the suspect ads, you can find the keywords and using a word processing program collect them to clean up your search so they do not appear. Another way to assist your search is to use quotation marks around the year and model you desire. Also make sure you are searching a specific area when using the quotes to make a focused product. Good Luck the ebay hacks know most of the tricks to present everything other than what you are looking for
Thanks guys, that explains it. I don't remember it being that bad in the past, I'll make a few adjustments to my search as suggested and should be OK. Richie.0
