GAS TANK DRAIN PLUG
TOM-WA-
TOM-WA- Senior Contributor
edited July 2013 in HUDSON
I HAVE 54 HUDSON WASP AND IT APPEARS TO HAVE A DRAIN PLUG
IF IT IS A PLUG I CAN'T FIND AN ALLEN WRENCH THAT FITS IT....COULD IT ME THAT IT TAKES A SOCKET WRENCH EXTENSION? IF SO WHAT SIZE
THANKS
  • duncan
    duncan Expert Adviser
    You can use a 3/8 short extension but you need to grind the male end to fit the inside of gas tank drain plug . Ray
  • Unknown
    edited July 2013
    If you happen to have a metal lathe and some cutting tool steel. There is probably a piece there the right size ,then put a wrench on it.
    Roger
  • Take care when removing this plug as one can twist the plug brazing completely out of the tank? Learned this the hard way!
  • Yep been there done that. Turned into the Niagara Falls of stale gas. Nasty.
