fan blades
Yes ,changing to a modern flex fan will aid in cooling. All other things being equal 20 degrees more cooling was gained when a friend put one on a 1949 Super with 262.
Get the right spacer for good right clearance,
Roger0 -
Any advice on the type or model number of the flex fan and the spacer needed.
The fan should be min of 3/4 of an inch from the radiator - I think anything over 1.5" and you'll start losing efficiency.0
We used a Imperial Flex Fan by Hayden # 221618 . I dont remember the size spacer off hand .I want to say 1" comes to mind but as stated above its whatever gives you proper clearance,
Roger0 -
Stay away from those plastic fans. Walt.0
I would not think a plastic fan is a good idea either . That Imperial one has Steel frame and flexible Stainless blades with good pitch to it. The centrifugal force straightens them as speed picks up . Provides similar effect to a clutch fan.
Roger0 -
Speaking of fans, it is a very good idea to thoroughly check the blades, pulley and bolts regularly. I have seen the aftermath of a wayward fan blade through a hood/bonnet. Scary.0
Be carefull if you buy a stainless steel flex fan. The blades are dangerously sharp and will slice you quicker than a ginzu knife.0
