36 Terraplane headlight and taillight pads
I know the 36 Terraplane did not come with headlight to fender pads, but did Hudsons come with them? Metro Moulded Parts sells pads for 36 Hudson but not the Terraplane. And another question is will the pads for a Hudson fit the Terraplane? I thought the headlights and taillights are the same.
I'm pretty sure they are the same on '36's. If there IS a difference, it would be in the headlight bucket and probably not the base (bases would be the same).
Not an expert on '36's, though. Verify. Verify. Verify.0 -
The Hudson & Terraplane headlight mounting and headlight assemblies are identical! Use them0
Thank you for the information, I didn't like the idea of bolting a headlight on a freshly painted fender without a gasket or pad.0
