Looking for a 1953 Jet exhaust manifold and the heat exchanger (single barrel).
Unknown
edited June 2013 in HUDSON
Hi everyone, I am hoping someone has a Jet exhaust manifold; as well as the heat exchanger that bolts on the intake in good shape. Both pieces on this Jet are cracked. I would fix it but I am not set up yet to weld cast iron.
Thanks
Brandon
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    brandon i have ione out in my drive way i'll check it out in the morning and let you know what kind of shape it's in
  • If its still bolted together and not cracked I advise installing as it is. The chances are if you seperate them one will crack .I have lost several that way that probably would have been good for some time if I had left well enough alone and installed as a unit,
    Roger
  • I will keep that info in mind, thank you Roger. Reminds me of working on Ford Model T exhausts; they have a bad habit of sagging badly if not kept tightened down. You would have loved the jig that my friend designed to straighten those manifolds, lots of fun.
  • Nevada Hudson
    Nevada Hudson Senior Contributor
    I will bring one to the National.
