Russell "Russ" Begg - engineer
Unknown
edited February 2013 in HUDSON
I am trying to obtain some information about engineer Russell Begg who by his obituary in 1957 and books on Holden cars he helped design, that says he worked at Hudson as a designer. He also engineered and designed Jordan and worked at Stutz after their chief engineer Charles Crawford left in January 1928. I am seeking if Begg designed the 1929-1930 Blackhawk by Stutz chassis and a friend who owns a Hudson Terraplane says the chassis of Stutz those years have many similarities... with his early 1930s Terraplane... which may be the Begg's Stutz and Hudson connection. But, someone at another forum said they don't know of Begg's Hudson connection... can someone shed some light here? Thanks.
The reason I am interested is because I am co-writing a book about chassis design especially X-brace designs.
Jim
  • bob ward
    bob ward Senior Contributor
    Cool, put me down for a copy when you are done. Can't help with info on Begg though.
  • hudsontech
    hudsontech Senior Contributor
    http://tinyurl.com/c4ssm3q
    Alex Burr
    Memphis, TN
  • terraplane8
    terraplane8 Senior Contributor
    This is from the original 2001 article mentioning Begg found on the wayback machine from the link provided by Alex above, http://web.archive.org/web/20021017005355/http://www.gmhistorian.btinternet.co.uk/HOLDENCARPROJECT.htm
    At this point we have to bring in yet another key player: RUSSELL S. BEGG. Begg was born in the U.S.A., and graduated in 1909 from the University of Michigan with a B.Sc. Degree. He then spent three years with the Packard Motor Company, then a period with the E.B. Thomas Motor Car Company, and then the Sheldon Axle Company. After that he was appointed Assistant Chief Engineer at Thomas B. Jeffery Motor Company, where he was responsible for Rambler and Jeffery motor cars. He was then appointed Chief Engineer to the Jordan Motor Company went the company was reorganised, and was in that post for 12 years. However, at the end of his period of tenure with Jordan, the E.G. Budd company took him up, where he gained valuable experience with steel body construction techniques as reputedly, their Chief Engineer. After this influential period with Budd, Begg moved to the Stutz Motor Company in Indianapolis, Indiana, and was appointed Chief Engineer. Presumably as Stutz went out of business, he was taken up by GENERAL MOTORS ENGINEERING, and appointed engineer in charge of design in Lou Thoms’ Product Study group in Detroit. It appears that he was appointed Deputy Chief Designer at Adam Opel A.G. in Rüsselsheim in 1934, at the same time as being a member of the P.S.G. He was then promoted in 1936 and reassigned permanently to Adam Opel A.G. as Assistant Chief Engineer. Earle MacPherson no doubt filled Begg’s position in the P.S.G.: see below so that Begg was not directly responsible for the Light Car Project, which he would, nevertheless, be involved with.
  • Thanks. looks like the article above doesn't mention his link to Hudson but his 1957 obituary " does as well as the Holden books. One entitled "She's a Beauty!: The Story of the First Holdens" says: Russell Begg, the leader of the Australian car project, was a distinguished car engineer and designer. He spent his early years with the Packard, Hudson, Jeffrey, Jordan and Stutz Motor Car Companies before joining GM in the late 1920s. " Somewhere else I seem to recall seeing that Holden provided closed bodies for Hudson at some point. Maybe that is the link?
    Again, any help appreciated. Seems like his stint at Stutz was short as well and not well documented outside of the SAE Journals?
  • terraplane8
    The article mentions the building of Hudson bodies in Australia.
  • Jon B
    Jon B Administrator
    I've never heard that Holden supplied bodies for Hudson (at least in the U.S.!). Hudsons were shipped knocked-down to Australia and assembled there by the Ruskin company. (Ruskin built bodies for several manufacturers and it also originated a couple of bodies for Hudsons which were not built in the U.S., such as the sloper (streamlined coach) and ute (precursor of the streamlined pickup trucks of the 1950's, like the American Ford Ranchero). Possibly there was a tie-in between Holden and Ruskin?
  • terraplane8
    Jon, quote from the article:
    In 1926, General Motors Export Company incorporated a new subsidiary, the aforesaid GENERAL MOTORS (AUSTRALIA) PROPERTY LIMITED, based in Melbourne and Sydney, and Innes K. Randolph was appointed the company’s first Managing Director: Randolph had been in one of the Indian Sales Offices with Graeme K. Howard and was promoted and moved by General Motors Export Company to Australia to head the new subsidiary. Laurence J. Hartnett and G.C. Sears had replaced Randolph and Howard in India. This was a proper assembly operation of chassis exported from U.S. Plants, Chevrolet kits being supplied from the Tarrytown-on-Hudson Assembly Plant which exported S.U.P. cars, with “22” prefixes [these were the special chassis with cowl as against fully C.K.D. until the 1929 Models which were sourced from Bloomfield Boxing Plant]. Holdens’ had started producing closed bodies for Hudson and Essex in 1925, and then for 1926 assembled bodies from imported packs which were virtually identical to North American bodies. From this point on, more and more local content was added. This work required the installation of a much larger panel press at Woodville, which resulted in the acquisition and installation of a 40-ton machine that could exert a pressure of 300 tons and process 160 panels per hour. Increases in demand and output in 1926 resulted in increases in floor-space, with the result that the company claimed that they were the largest of their kind in the Empire outside Canada.
  • Spencer Yarrow
    Spencer Yarrow Expert Adviser
    Holden did indeed build bodies for Essex in 28 and 29 and also in24 they did sedans on
    1919-21 chassis there are many photos in The History Of Holden By Norm Darwin.
    published by
    E.L.FORD PUBLICATIONS Pty. Ltd.
    NEWSTEAD, VICTORIA 3462
    AUSTRALIA
    not sure if they did Hudson bodies.
    Spencer
  • StillOutThere
    StillOutThere Expert Adviser
    This '34 Terraplane has a Holden body.
  • Still Out There... you know me, I am sometimes not just "still" out there but "WAY" out there 8-} Thanks for sharing!
