Help. Re-babbiting Connecting Rods
Unknown
edited December 2012 in HUDSON
Hi there. After pulling the engine out of the '37 Terraplane and waiting for a decision on the inserts vs re-babbiting, turns out I am forced to do the latter. Looking for suggestions as to the best place to get the work done.
  • hudsonsplasher1
    hudsonsplasher1 Senior Contributor
    What part of the country do you live? Maybe someone in your region or local chapter can suggest a shop close to home that can do the job for you.
    Gene.
  • Unknown
    Just south of Buffalo, NY. Egge was suggested by my machine shop with a three month turn around time...maybe...
  • Seem's like 21st Century Hudson does that (Randy Maas), may be wrong wont hurt to ask
    Roger
  • Geoff
    Geoff Senior Contributor
    Egge machine also do them.
  • Ol racer
    Ol racer Senior Contributor
    I think Randy Maas will get them done for you too.
    Chuck
  • PAULARGETYPE
    PAULARGETYPE Senior Contributor
    joycescheetz i have some nos rods that are in my stock i'm not sure if there long or short i know there are 3 left and 3 right email me the over all lenth of your rods and i'll check if what i have will help you out email is HUDSON1957@AOL.COM DROP THE HET
    ALSO IF MINE DON'T FIT PITTSBURGH CRANK SHAFT DOES THEM I CAN GET YOU HOOK YOU WITH THEM ALSO
  • SuperDave
    SuperDave Senior Contributor
    Randy Maas has one of my eight cylinder rods as we speak. He does great custom work.
  • Kdancy
    Kdancy Senior Contributor
    http://www.babbitt-bearings.net/
    Just wondering if anyone has had experience with these guys?
    More-
    http://www.google.com/search?q=pauls+rod+and+bearing&ie=UTF-8&oe=UTF-8&hl=en&client=safari
    More from the AACA
    "Paul's Rod and Bearing in Missouri. They've done several engines for us."
    Hart's Machine Shop, Cecil, Ohio
    They do superb work and have a speedy turn around time.
    Good luck!
  • hudsonsplasher1
    I would stay away from Egge. I had a bad experience with them.
    Gene.
  • @ PAULARGETYPE - the engine is out and at a local machine shop for rebuild. If you could give me measurements for the ones you have in stock I can put a call into the shop to measure the ones they pulled. Thx.
  • Jon B
    Jon B Administrator
    Regarding NOS rods: assuming that Joyce could obtain some NOS babbited rods, would she not want to have the machine shop balance them as Hudson had done originally, for a smooth running engine? Didn't Hudson weight the rods and make sure each one weighed the same as the others by grinding off metal?
  • Unknown
    Yes
  • Unknown
    This is an example
    Roger
  • Geoff
    Check out this website. They still do centrifuged bearings!
  • @ Geoff and Ken - I am going to investigate this option.
  • PAULARGETYPE
    I'LL MEASURE THEM TODAY WILL POST BACK!!
  • Unknown
    @ Paulargetype, thanks so much. I am checking all my options but NOS is certainly appealing .
  • oldhudsons
    oldhudsons Senior Contributor
    This guy has been in business for decades. He's done Hudsons all the way from a '13 6-54 up to late 8's.
    Vic Terell in Escondido, Cal. (my old stomping grounds), at 760-749-9663, call only on Mon., Tues., & Wed. There's also a great shop in town for grinding cranks & line boring too as well as a body & paint shop that specializes in doing vintage iron.
  • @ Geoff - going with Karr in Montana. Hubby talked with the guy and he seems very knowledgeable. Turnaround in three weeks (hopefully...) The machine shop also spoke with him and were happy with what he had to say on the subject. :-bd
  • Kdancy
    Let us know how it goes. capable shops are getting scarce!
  • Jon B
    Jon B Administrator
    Joyce:
    Here is another re-babbitter, given to me by a local old-car garage. But the garage owner has no experience with the fellow, merely word of mouth:
    Terry Harkin
    903 43rd Street NE
    Watertown SD 57201
    605-886-7880
  • Kdancy
    harkin did a set of rods for me and they weren't center bored, I won't use them again.
