Wanted '35 rear stabilizer bar assy. from Axle-Flex car
StillOutThere
In 1935 any Hudson or Terraplane that had the Axle-Flex front suspension also came with a rear stabilizer or "anti-sway" bar. This '35 stabilizer could be retrofitted to '34s also per Hudson literature. I have a '34 with Axle-Flex and would like to find a complete '35 stabilizer bar with brackets to mount it from a parts car or a hot rod where these parts are removed. Until one is found I'd appreciate it if someone can post pictures of what the original looks like. Thanks
Graeme, these are some 2 shots of an upside down 35 chassis with a rear sway bar, the bar is 13/16" diameter.
[IMG]http://i237.photobucket.com/albums/ff28/sirrobertthegood/IMG_0005-1.jpg[/IMG]
[IMG]http://i237.photobucket.com/albums/ff28/sirrobertthegood/IMG_0006-3.jpg[/IMG]
And this is how the links attached to the back axle, there is an extra plate with suitable link hole, it is held onto the underside of of the normal plate by the U bolts.
[IMG]http://i237.photobucket.com/albums/ff28/sirrobertthegood/IMG_0007-1.jpg[/IMG]
I don't know that I have any links to show you, but if I come across them I'll take a photo.0 -
OK, the photobucket links aren't displaying correctly, I'll try the file attachment method0
- 182 The Flathead Forum
