Leaking overdrive solenoid
I have a leak at my overdrive solenoid that seems to get worse by the day. I put gasket seal on it and when that didn't work, I tried to form a gasket from some gasket material I had lying around, and that didn't work either. The repair manual mentions a solenoid seal. Anybody know where you can get one of those?
Thanks,
Jason
Thanks,
Jason
Try Jason @ Vintage Coach, Tues thru Sat. 8am till 5pm. That seal is pressed into the adaptor casting where the solenoid goes. Be sure to clean the lube out of the solenoid especially the c ontact points, both sets.0
