Hydramatic filler floor-plug for Hornet needed.
Need the plug that fits in the hole in the floor through which you check and add Hydro tranny fluid. I know they're a "high-casualty" item (checked with Jason Fisher and Gene Eshelman) but thought I'd put the word out. Any condition as long as it's mostly still there is fine. Thanks, Bob
**==0
Try your hardware store, mcmaster-carr or grainger. I could have sworn I found a found the right size at mcmaster-carr.0
Grim Greaser, I think he's talking about the cover in the floor and your talking about the plug in the tranny itself.0
I f you need one I should have some. I will check my warehouse this afternoon
Roger0 -
that's what I mean, the 2 1/2" plug for the floor. I found them somewhere. McMaster has plastic hole plugs to 2 1/2", but I think I found the metal ones too.
Plastic:
http://www.grainger.com/Grainger/Hole-Plug-1ELY40 -
I grabbed you the wrong piece ,I see now what you want - the round ones .I will check again for those .Should have some of them too,
Roger0 -
How about this , is this what you are after? Its hard to see in the photo but all the little tabs are there that hold it in,
Roger0 -
Roger - I could use one of those plugs for my '54. How do I get in touch with you. Also, in some '54's they had a larger rubber plug that you would remove from the carpet to get to this metal hole plug. Do you have any of those?
Jerry0 -
I dont have any of those rubber ones . I know there is two of these round metal ones in stock right now. My phone number is :636-448-3878
Roger0 -
Thanks so much guys; I found one locally. Been busy and dropped the ball, but thanks for the input.0
Have one of the rubber larger ones if still needed. russmaas@frontier.com0
- 182 The Flathead Forum
