!957 Hudsons
YES THERE ARE CROSS OVERS
55,6,7 HUDON WHEEL CYL'S FRONT 1 1/8 " DIAM. SAME AS 60 TO
63 CHEVY TRUCK 3/4 & 1 TON
55,6,7 REAR 7/8 "DIAM SAME AS 61 62 T BIRD AND MERCURY HD
55,6,7 BRAKE LINES SAME AS 52 TO 54 HORNET WAGNER #24404
IF YOU NEED MORE INFO CONTACT ME AT HETHUDSON1957@AOL.COM OH YEA REMOVE THE HET FROM THE EMAIL ADDRESS IT'S TO KEEP THE SPAM DOWN
Great, I have printed and copied to a word file. I'm new to the 57s so have to determine where parts are. The brakes may be the first thing I have to tend to on this car. I imagine 57 gas tanks are rare.....mine isn't leaking, but I believe this tank must have seen a logging road a time or two as it's beat and dented like I've never seen before ON a car. Would you know what the little toggle switch UNDER the dash all the way to the left almost to the door is for? I see nothing in the owner's manual about it but it seems original, Just got the car and haven't tried to trace the wires yet.0
THAT SWITCH WORKS THE UNDER DASH LIGHTS
should be logged in now. Had password difficulty again.0
Thanks Paul, I'll check into it. I did notice a loose rather large bulb on the opposite side of the dash, so now know what to look for.0
