308 Cylinder Heads
I can see enough of only two of the aluminum heads, the H-145 is most likely a 51-52 308 optional head (7.2:1 CR), the one to the right appears to be a '53-54 308 7.5:1 CR, the one out view? I can't tell without seeing at least the front half. The 500 head, probably pre-51.0
Mike the heads and give the thickness of each. All heads are 2 inch new and was allowed to be cut 0.060". The 500 head is for the 232 Pacemaker, check width, 1950 or 51 to 53 which were wide blocks. Walt.0
