positive or negative ground
I am wondering if someone here can tell me if a 1930 essex is positive or negative ground? I removed my battery when i sent my carb to get rebuilt 2 months ago....I just got it back on the super six and forgot which ground was correct,I tried touching the cables both ways and it didnt spark and I know for a fact ford model a are pos ground. the guy who sold it to me said the starter wire goes to the pos post so it would be a neg ground ,opposite of a ford.....anyone help? thanks John
Your Essex is positive ground. Ground the positive terminal of the battery - only.0
On our 30 Essex the negative side of the battery is grounded to the frame.0
My '33 is negative ground, I'll bet yours is also, but I won't "guess". Do yourself a favor and round up a spec sheet (single page,both sides full of mechanical and electrical specifications) on your '30 Essex,they are easily found on the internet thru literature vendors such as Walter Miller. It would be good to know what year Hudson switched to a Positive ground.0
Hi---Not positive, but I think a 30 Essex was a negative ground system. Hudsonly---Cliff Minard0
From a 1930 Essex electrical data sheet it says:
BATTERY:—Exide, Type 3-XI-13-1G, 6 volt. The negative (—) terminal is grounded. Starting capacity (20 minute rate) is 98 amperes for 20 minutes. Lighting capacity (5 ampere rate) is 5 amperes for 17 hours. Battery is mounted on the left frame member under the driver's seat.
This data sheet, and other Essex info can be found at:
http://hetclub.org/burr/lithomepage.htm - under 1930-1939 click on Reference sheets, and then on 1930 Electrical Data.
Alex Burr
Memphis, TN0 -
Richard E. wrote:Your Essex is positive ground. Ground the positive terminal of the battery - only.
Negative ground, Richard, negative ground.
Alex Burr
Memphis, TN0 -
Sorry guys & girls, I thought that all Hudsons were pos ground. Learn something new everyday!0
In fairness to you Richard, Hudson switched over to positive ground with, I believe, the 1934 models. Some electrical whiz kid decided that them little electrons were running around from positive to ground, instead of negative ground thus changing everything around.
Alex Burr0
