Manifold ID needed
Having the W-! carburetor, it will fit 33 to 39 212 engines that have the W-1. Starting in 1937 some Hudsons and Terraplanes started to use the WDO 2 barrel Carter carbs. Walt.0
1933 to 1936 manifolds are smaller than later models . 1937 to 1947 have either single or dual throat manifolds, depending on model. 112's had only single throat.0
