Update on 52 Coupe Project
It's looking good. I see you got the backlights you wanted. What's with the blue tape? Looking forward to seeing it completed. Are you going to put the NASCAR license plate brackets on?
Have a great day.
Lee O'Dell0 -
Hi Lee,
The guy is tapeing the stainless in some areas to see where it fits (his first Hudson). The backlights turned out well. I had to reuse the black rubber spacers but freshened them up. Definately will have the license plate brackets!0 -
Not to be smarty, but wouldnt it be better to color sand with trim OFF? RD0
Yeah, I think he was trying to figure out how the side trim goes on. It's a B**** to put on w/o damage.0
The windshield stainless is put on the opening before glass is installed. Apply a thin line of sealer into the opening before you press it on. Then the 2 center stainless on the center post and use body DUM-DUM to seal both ends. If not it will leak in a rain storm if you drive your car in that kind of weather. Walt.0
