tie rod ends 1954 Hornet
Rareparts.com in Stockton CA has them at $90.00 and $93.00 each0
Some Chryslers and Fords of the period used the same tie rod end. Don't know if those varieties are cheaper than the Hudson item.0
I think 40-48 Ford pass is the same. Tomorrow I will check the Moog and Thompson catalog and post the. numbers.
Bruce0 -
Try NAPA 269-241 and 269-240. Also Moog 4004 , EIS 147.0
Kanter might have them though probably not the cheapest of your options.0
Hi All,
My listings show the following for 48-54 Hudson:
1948 – 1954 Tie Rod Ends
Moog: ES 416 L&R
ES 64 L&R (old #)
Thompson: ES 147 L&R
McQuay-Norris: Same as Thompson
NAPA: 269-2241 (R)
269-2240 (L) I may have an extra 2 in here.
Bruce0 -
Thanks everyone!
NAPA here has the 269-2240(L) and 269-2241(R)tie rod ends, and though they don't identify them as fitting Hudsons, they do fit a number of cars of the stepdown era, including Ford. I'll take L & R threaded ends down to them that came fom a '52 Hornet, one of which bears an H with a triangle and hexagon stamped on the bottom. I understand this is original equipment, so should be good for comparison. Will post results. Price quoted as $42.xx per.
Walt-LA0 -
I have these numbers in my parts list
Tie Rod End Auto Star ASES140R R outer, L inner 36 Thru Stepdown
Moog,Mq ES140R SPI 401-1005 Auto Zone 26385 NAPA 269-2241
Tie Rod End Auto Star ASES62L L outer, R inner 37 Thru Stepdown
Moog,Mq ES62L TRW ES324R Auto Zone 26386 NAPA 269-2240
I contacted Rockauto.com and although they didn't list them under Hudson, they have the Moogs at least under their Part Number Search at $33 and $38 respectively. They ship next day. Service and parts are great.
They list a lot of parts for Hudson at great prices.
I first got a tailgate latch from them, a Dorman part. Local Toyota dealer quoted $87. They sent me one for $38 plus about $4 for shipping.0
