Brake Pedal Assembly?
RL Chilton
Administrator, Member
Can't seem to find the info I need. Question: For stepdowns, is the brake pedal assembly the same whether one uses a standard tranny or automatic, with simply the removal of the clutch pedal for an automatic?
Call the 'Twin-H-Ranch' tomorrow and ask for Robert. He sould be able to answer that question for you. 909-823-9168 Tues. to Sat. 8am to 5pm.0
It seems like it's the same pedal except Pacemakers, Wasps, Jets and Power Brakes. 48-54 part #300404. It also seems that the short wheelbase cars with Hydramatic also have a different part #.0
RUSSEL THE PEDAL ASSEMBLY IS THE SAME MINUS THE CLUTCH PEDAL FOR HYDRAMATICS0
hudnut52 wrote:RUSSEL THE PEDAL ASSEMBLY IS THE SAME MINUS THE CLUTCH PEDAL FOR HYDRAMATICS
Thank you! Now the next question is, what replaces the clutch pedal arm, if a clutch is not to be employed?0 -
Don't know for a fact but I would assume that a spacer was used to replace clutch pedal on an automatic. I suppose if you had the whole assembly you could just cut off the clutch pedal at the pivot point, - if you didn't want to make a spacer.
Jim Spencer0 -
J Spencer wrote:Don't know for a fact but I would assume that a spacer was used to replace clutch pedal on an automatic. I suppose if you had the whole assembly you could just cut off the clutch pedal at the pivot point, - if you didn't want to make a spacer.
Jim Spencer
I had thought of that, but wanted it to be "original". If nothing else comes of it, that's my plan.0
