Master cylinder number for a '37 Terraplane
Doug, jf this is the same M/C as the later cars w/ the 3 bolt triangular pattern mount,it's usually available off the shelf at a GOOD parts store. It was used on most/all Ford products incl trucks 39- 48 and lots of industrial applications, ie fork lifts etc. Try it you may luck out!0
The old Backus interchange book shows NAPA/United 4360. It may have been changed later, but usually they can find it with the old number.0
