Governor gear needed
hudson1948
Does any one out there have a 16 tooth governor gear for a 49 Commodore 8 with overdrive. Stewart warner # would be 448212 or 448214 according to parts book. Thanks Charles S.
It's the gear that attaches to the governor. The one on the on the opposite side of the speedo cable.0
Check with Dr. Doug, aka "clutch guy." I'll bet he's got one.0
hudson1948 wrote:Does any one out there have a 16 tooth governor gear for a 49 Commodore 8 with overdrive. Stewart warner # would be 448212 or 448214 according to parts book. Thanks Charles S.
Might want to be careful here. One is a 16 tooth gear the other is an 18 tooth gear . Do you know which one you actually need?0
