Jet---Upper Outer Support
HI everyone, my Jet needs "Upper outer supports" for the front end. It consitsts of a long bolt and a nut, a bushing and several rubber seals. Does anyone have a part number for this? The parts book is unclear so I am not sure what to ask for. Does anyone know if this part is the same that was used on stepdowns? Any help on this will be appreciated. These parts need to be replaced on both sides of my Jet. Thanks, Dave
This is the Jet's "Achilles heel". The parts you need are in the catalog, Ill. no. 2, page 14, in the lower left diagram. Support A1-26A 308220. Bolt A1-29 308223. Seal A1-27 308229. (Both in the main diagram) The problem with the illustration is that the main drawing is of the Step-down larger car suspension, and they have aded the supplemental drawing for the specific Jet parts. Dave Kostansek should have these parts.
Geoff.0 -
Geoff, thanks for the info. I will give Kostansek a call and see what he has.0
