WA-1 Carter
Rudy-What is the tag # on the carb.? What year & model is it for? I have some Carter info sheets & may be able to help. Norm0
For the single carb application, or twin-H. I have the 53-54 Jet Carter Carb sheet for the Twin-H. -2013S
Alex B0 -
hudsontech wrote:For the single carb application, or twin-H. I have the 53-54 Jet Carter Carb sheet for the Twin-H. -2013S
Alex B
They are the orignals that came on the 1952 308 engine.
And do not have a tag. Thanks Rudy0 -
HI I HAVE FRESH REBUILD KITS FOR WA1'S THERE $5O + SHIPPING FOR 2 I CAN BE CONTACTED AT HETHUDSON1957@AOL.COM JUST DROP THE HET FROM THE EMAIL ADDRESS AS THAT KEEPS THE SPAM BUGS AWAY0
Rudy, I have all the info you need. Will post tomorrow afternoon or evenning. I do know the jet size off the top is 101.5 I have all the numbers for the idle circuit & metering rod numbers.
Randy0 -
Rudy-An old Chilton manual says your '52 308 (Twin-H) would have a WA-1, Tag #968S. I have a Hudson sheet with a lot of metering rod #s for different Carter carbs. The standard metering rod for a 968S is #75-834. The specs. for this rod is- Length-3 9/64". Economy step- .076" dia. Middle step tapers to- .063" dia. Power step- .056" dia. The sheet also shows metering rod- one sizes lean- 75-861.. 2 sizes lean- 75-862. 3 sizes lean- 75-863. I don't know if this will help. Norm0
herm wrote:Rudy-An old Chilton manual says your '52 308 (Twin-H) would have a WA-1, Tag #968S. I have a Hudson sheet with a lot of metering rod #s for different Carter carbs. The standard metering rod for a 968S is #75-834. The specs. for this rod is- Length-3 9/64". Economy step- .076" dia. Middle step tapers to- .063" dia. Power step- .056" dia. The sheet also shows metering rod- one sizes lean- 75-861.. 2 sizes lean- 75-862. 3 sizes lean- 75-863. I don't know if this will help. Norm
Thanks to you NORM for the info,and to Randy,Ill be looking for your Info tomorrow evening.
Hudsonly to all Rudy.0 -
Rudy--also the metering rod jet is .1015" dia. Norm0
Rudy,
968-S 2113-S
Low speed jet .035 .033
Meter Rod jet .1015 .1015
Meter Rod 75-834 Std. 75-955
75-861 1 lean 75-974
75-862 2 lean 75-975
75-863 3 lean 75-976
Idle screw seat .084
Accl. Pump Discharge jet .0225
Need more info--I hopefully have
Randy0 -
Thanks Randy for the info. It is what i was needing. Hudsonly Rudy.0
Just a matter of curiosity, since by this time, many carbs have lost their tags. Is the model number stamped on the carb somewhere?0
- 118 Hudson 1916 - 1929
