Parts Wanted
I've come up short trying to locate a speedometer and glove box panel for my '41...
It appears to me that the dash (speedometer) and glove box panels for '46 and '47 are about the same size and configuration as the '41s (don't know about the '42s. If this is not the case someone please let my know.
If the 46 - 47 panels are the same (or even close for that matter) then I am looking both panels (driver's side and glove box) with serviceable gauge faces (lettering). It would be nice to find some that are at least driver quality but all conditions will be considered. Gauges don't need to be working and even there... the main thing is finding the faces and any parts that I can get to rebuild the set I have.
Thanks,
Craig
Thanks,
Craig
Craig - I think you'll find the height of the clusters are not quite the same. It runs in my mind that the lens area is somewhat shorter top to bottom. Of course, the length would have to be the same, as the glove box and panel the speedometer mounts into are the same on all '41 thru 47. There are a couple of members that visit this site now and then that specialize in '41s - maybe they will chime in here soon.
Jerry
53jetman0 -
Craig, if you are wanting instand gratification you are probably not going to get it. If however, you are willing to wait and look, you will find what you are looking for. I know these panels are out there because I have bought one for myself so I can figure out a safe way to detach and reattach the cluster face without messing up my good one. If you have no luck email me.
Allan0
