Need Idler arm for '54 Hornet
Are you refering to the center point steering arm and pivot?0
Hudzilla wrote:
Yes. The bearing is failing on the idler arm (opposite from the pitman arm from the steering box). Any NOS or refurbished available?Are you refering to the center point steering arm and pivot?0 -
The bearings are available. You MAY be able to locate a center arm pivot. Clifford reproduced those years ago. Someone currently reproduces them, they'll chime in I'm sure. Anyway the chances of finding NOS are slim and none and Slim just left town. If you want a decent used setup let me know.0
