Engine & tranny for 47 pickup
The flywheels are not interchangeable between 9 and 10" clutches.0
However, it is my understanding is that the transmission, bell housing, and throwout bearing are interchangeable, is that correct Geoff?
(The bell housing needs to be matched to the engine, but it should align to the transmission & clutch assembly without issue (?))
Yes, all you need to change is the flywheel and clutch unit, everything else fits.
Geoff.0
