driveshaft parts
The center bearing is s'posed to be Napa BR 88507
The bushings are available from KGap0 -
Here are the part numbers for the bearings.
'48-'52 All Exc Pacemaker and Wasp use #88506
'50-'52 Pacemaker and Wasp use #88107
'53-'54 All Exc Jet use #88107
I am not totally sure about the above infomation. So here are the dimensions of the bearings. You can measure yours and pick the right one.
#88506
ID 1.1811 inchs
OD 2.4409
Width 0.9449 inchs
#88107
ID 1.3780 inchs
OD 2.8346
Width 0.9843 inchs0 -
Thanks for the replys. I want to have the correct parts on hand if needed. The driveshaft has a vibration, so I'm thinking it may be the bearing.0
We Stock Both Bearings And Cushions Here At Vintage Coach, Fontana, Ca Bill Albright0
