Crank pulley on H8 vs. H6
The same OD of the crank for the harmonic balancer part of the switch0
50C8DAN wrote:
All crank pulleys 6 and 8's are the same from 1937 up. Single or double pulley. Walt.I have finally obtained a complete long wheel base PS unit from a '54 Hornet that I plan to use on my '50 C8. Does anyone know if the crank pulley from the Hornet will work on the H8 so I can use the dual pulley setup to drive the pump?0 -
Great thanks for the info guys!0
