? on Steering column removal
Remove shift lever, direction indicator, steering wheel, under dash clamp, and linkage to automatic indicator
Under the hood, disconnect tranny linkage, and pull the pittman arm.
3 nuts hold the box to the frame studs. Remove nuts, slide the box off the studs and slide the whole thing down thru the floor and out thru the engine compartment.
If you get hung up, email HETcramerlp@roadrunner.com and remove the HET0
