Starting the '49 super six
Hudsonrules
I installed that very Car Quest number 6737 fuel pump in my '49 Commodore six coupe. I used a 7/16" spacer. I also found that I needed grind some material off the top inside of the gasket to clear the pump arm. This is probably what is causing your install problem.0
